TNtim
I got 69k on the NC... replacing the coolant with "Evans Waterless Coolant". Doesn't boil, doesn't build pressure, doesn't corrode engine, doesn't conduct electricity . Any comments or users?
I'd wonder what are the ingredients. Does it contain silicates (bad for motorcycle water pumps)???
Back in the day I owned cars with cast iron or steel engine blocks. A flush of the water jacket and radiator often was a torrent of brown rusty water with chips of rust. The water pump was also a steel housing containing a steel impeller. Jay Leno's collection probably has a number of older vehicles with iron blocks and I can understand a waterless coolant in a machine that does not get a lot of use. Water itself encourages corrosion so coolants containing water are mixed with glycol & other fluids as well as anti-corrosion additives. Properly mixed and maintained with glycol based coolant iron block engines do not rust or at least they rust so slowly that it is not an issue, engines don't die from overheating caused by clogged coolant passages like they used to.I don't know how much weight to put on it, but Jay Leno runs it in most of his cars. He says that since it doesn't have any water, which contains oxygen, which in turn promotes corrosion. During this weeks webisode he mentioned that the seal on one of the water pumps developed a leak, figuring it would be hard to take apart to repair. He said the screw holding the impeller, which on regular coolant is very hard to remove, came out with just a normal screwdriver and not much force. YMMV
Old fashioned glycol based coolants seems to do just fine for me.
If the NC700X coolant system is in good operating condition overheating shouldn't be a worry.Evans _is_ glycol-based. It's usually propylene glycol, but without water. Sometimes other glycols. I'm always concerned about lower specific heat than 50/50 since it has no water. Where I live, overheating is still a reality.
No-Rosion Products Technical Questions and Answers
