buckshot
As much as I love my S, I couldn't stand the yellow accents on the frunk and the stickers. I hate yellow, the only think it looks good on are extra-terrestrial robots that resemble camaros.
So I pulled the NC700S stickers off the side, and removed the frunk boomerangs. Really easy, 2 screws each on the underside of the frunk lid.
These are where they're located on the S, likely slightly different on the X.
![boomerang bolts.jpg boomerang bolts.jpg](https://www.nc700-forum.com/data/attachments/4/4180-7675b3641fed95b5ad2e45a4f058b850.jpg)
And here she is with no boomerangs.
![no boomerangs.jpg no boomerangs.jpg](https://www.nc700-forum.com/data/attachments/4/4181-48014a90c02153a57c6b538a17abfc26.jpg)
![no boomerangs 2.jpg no boomerangs 2.jpg](https://www.nc700-forum.com/data/attachments/4/4182-e1e1acda9fd648463bf644a14734fa0c.jpg)
We all know what grey primer looks like, so I'll skip that picture. Just if anyone else tries something similar I highly recommend roughing up the boomerangs with some 400 grit wet/dry, then using a good plastic primer after that. I goofed that part up a bit, first coat of regular primer wiped right off after 30 mins. I was not impressed. I cleaned it off, scuffed up the plastic, then re-applied it and it seemed to stick fairly well. It still looked rough after 2 coats and light sanding, so I hit it with some dublicolor filler-primer. That stuff is amazing. One coat got rid of 99.99% of all the imperfections, and everything stuck fine. Onto the meat and potatoes.....
On goes the first coat of base, Plum Crazy....
![first coat base.jpg first coat base.jpg](https://www.nc700-forum.com/data/attachments/4/4183-93342c23dd8817263b3e00d122309afc.jpg)
Aw yeah, purple baby! Courtesy of my local NAPA and all the best looking Mopar muscle around! Damn I'm stoked.
Here they are after 3 coats of base and 4 of clear.
![final clear.jpg final clear.jpg](https://www.nc700-forum.com/data/attachments/4/4184-9d157b2d8675714747dadc82ee62ea57.jpg)
I'm fairly new to autobody type stuff, and so far I think they've turned out amazing if I do say so myself. I'm just waiting for everything to dry up then I'll be on to re-fitting them to the frunk lid. Pictures will follow, hopefully tonight.
All of this was done with spray cans, no fancy tools. Though maybe one day.....
P.S. That's not a real rifle in the 1st pic, just an air rifle. The chipmunk insurgents have been infiltrating my outer perimeter all spring, and they get pretty ballsy without Dog around.
