GunNut37086
The heat index here has often been over 100 lately, so ya gotta keep hydrated while ya ride.
My wife says I'm a drama queen for whining about having to pull over, take off my gloves, remove my helmet, dig out a bottle of water, swallow as much as I could hold, gear back up, and get back on the road, but it really is a pain in the butt when you'd rather be riding. I tried a Camelbak first, since it's the most common solution. It worked okay, but was uncomfortable after a while and got hot after the ice melted. Plus, I hate cleaning them out, especially the hoses. I had an idea of mounting something on my bike. I tried mounting my Camelbak behind me like a tailbag, but the tube wasn't long enough. Getting a longer tube means more nasty water to swallow before you get a good drink...ergo more whining and thinking.
I drink up at stops anyway, so I really only needed enough water to last between stops. I decided a 1 liter Nalgene bottle would be about the right size for the road. I'm usually ready to stop by the time it's empty anyway. After some searching around on the interweb for a ready-made solution, I gave up and picked up what I needed off of eBay. I needed a hydration tube and lids for converting a Nalgene bottle to a hydration pack (has numerous lids to fit other bottles to). This thing works great and doesn't leak. I may eventually change out the bite valve for a 90 degree Camelback bite valve, just to make it easier to use under the chin bar of my full face helmet, but it works fine now...just isn't perfect and I tend to whine about anything less than perfection, LOL. I also got a water bottle holder with molle straps for mounting. I also considered this high-speed/low-drag alternative that's much cheaper, but I wanted the zipper pocket on the other one to hold energy bars or peanuts or whatever. I had the other stuff I needed lying around the garage.
Here's the Nalgene bottle with the hydration tube:
Here's the botle holder with nylon webbing and mini bungee cords attached for mounting (I used a length of bicycle inner tube to keep the bungee hooks from scratching my frunk):
Here's how it's mounted at the top using a mini bungee cord (this keeps the cord from compromising the frunk seal):
The clips I made from 1/16" kydex using a toaster oven, a drill, and a file:
The clips hang on like this to the edge of the lid (also doesn't compromise the frunk seal):
Here's the whole contraption mounted:
