kevicon
Is the 10.9 grade the only bolts that should be put in?
Sent from my RM-860_nam_usa_100 using Board Express
Anyone fitted highway pegs on the Givi bars ?
Here are the numbers for the engine bolts on the US spec 700x with manual transmission (not DCT). All are grade 10.9 M12-1.25 hex washer head bolts.
UPPER LEFT: 35mm long bolt with 7mm from face of frame flange to start of thread
UPPER RIGHT: 45mm long bolt with 17mm from face of frame flange to start of thread
LOWER LEFT: 80mm long bolt with 46mm from face of frame flange to start of thread
LOWER RIGHT: 55mm long bolt with 30mm from face of frame flange to start of thread
The upper right bolt can be re-used on the upper left. I purchased three new bolts in 55mm, 70mm (65 was not available), and 90mm length.
The only comment to do is that the measures of my original bolts were a little bit different to the measures taken by Beemer. It is strange, although my bike is european (spanish) and equiped with ABS, I don't think these are enough reasons for the different bolts...
Below, the measures of my bolts:
UPPER LEFT: 35mm long bolt with 4mm from face of frame flange to start of thread
UPPER RIGHT: 45mm long bolt with 12mm from face of frame flange to start of thread
LOWER LEFT: 80mm long bolt with 48mm from face of frame flange to start of thread
LOWER RIGHT: 55mm long bolt with 23mm from face of frame flange to start of thread
A couple of washers here and there did the job pretty well, and the original upper right bolt was used for the upper left as well.
HTH
Can I also re-use the lower-right bolt for the upper-right?
When un-bolting, is it safe to have 2-bolts on a side un-bolted, since upper-right will be out first, followed lower-right (assuming it can be re-used)?
i would not do that. It wouldn't improve strength and the rear of the threaded bosses is not flat so the nuts would not seat properly. The small contact area might even increase and localize stress. Another problem with 20mm longer is that you might have problems getting enough threaded length to match the start of threads depth in the holes.Is it ok to use a 20mm longer bolt and put a nut at the other end?
I can only find these black bolts. Sizes are correct. Am I better off using back the 4 original bolts?
Also, is it ok to use stainless steel washers with these bolts?
