BrNaCa
I just installed the Honda light bar. On my bike the right side bar is much closer to the body work than the left side. Is this normal?
Hey, Sergeant! How did you manage to stick the base clip for the GoPro onto that plastic piece ????
I cleaned it with alcohol, used the original tape on the mount - fell off fast... tried the high bond tape - fell off anyway... Looks like that surface is porous to grab.
The trick is to install the frame clamps loosely then install the hardware beneath the beak. Adjust the the bars by sliding them on the frame tube to align them correctly. Once the alignment is right, then tighten the front hardware and the frame clamps lastly.
^^^^^^does he plan on dropping it allot
Will the light bar work with he Givi crash bars? If this is a peice of steel pipe attached directly to the frame why won't it help protect the plastic? Is it so weak that you could put it over your knee and bend it? Will it work with the upper air deflectors? It looks really close in that area.
The light bar might prevent some damage to the bodywork in a tip over, but honestly it may very well bend inward and create more damage. I can only speculate on this, but maybe someone with a light bar that has tipped over, will reply and let us know if they believe it helped save any plastic.
The SW Motech protection bars (shown in Sergeant's post) will mount with the light bar, but I don't think the Givi ones will work with the light bar. The Givi design has a welded tube clamp close the same spot as the OEM Honda light bar tube clamp, on that frame section.
Upper wind deflectors and the light bar fitment? Yes they will work together, I believe.*
* don't quote me on that, though
I've dropped my bike three times (light trails with wet grass). I don't think the light bar came close to hiting the ground but I have saddle bags on 24/7. Between the saddle bags and the handle bars I bet I still have 4" of clearance prior to the light bar.
I wonder how the plastics would fair without the saddle bags installed.
