GunNut37086
A few weeks ago I was pulling my NC into the garage after commuting home. I was just sitting there on my bike. I'd taken of my gloves, jacket, etc., but not my helmet yet, because I was finishing a scene in an audiobook. Well, I stepped off the bike and down she went. Yep, I had forgotten to put the sidestand down. Funny how that small break in my routine made me forget something so basic.
Luckily I only did minor damage to the bike, but I tweaked my wrist trying to stop the fall and it's still sore. I bent the gear selector, curled the end of the clutch lever, and scratched the bar end...nothing major. I was able to fix the bent gear shifter, but had to order a new clutch lever. Who cares about a scratch on the bar end?
I told you that to tell you this:
I got a new set of adjustable/folding levers in the mail and when I went to install them I noticed my clutch screw was already partially unscrewed. The cap nut had fallen off and the screw had backed out. Luckily I was already changing levers or I may not have noticed until something bad happened. With an improvised cap nut and the new levers installed and adjusted to my liking it was time to test ride...only, my bike wouldn't start.
I figured my clutch wasn't adjusted enough to trip the clutch switch so I played with it for an hour trying to get it to work. Nothing! My bike will only start in neutral. I did some testing and inspecting and my clutch switch is broken. I'm guessing the cap nut fell off, the screw backed out, and using the clutch without noticing sheared off the plunger on the switch. So, I can only start my bike in neutral until the part arrives.
...confession is good for the soul, even if it's embarrassing. On a scale of 1 to 10, how dumb was this mistake?
