Azer350
I am curious as to wether it will break off at higher speeds.
Did you reenforce it somehow?
The Honda plates will work with Calsci shields, but not with Parabellum shields. Parabellum spaces out the mounting holes to match the upper upper and lower lower mounts to spread the load out wider. Dale's plates will work with them since his cover all four sets of holes at once.Jlandon, if you have the Tall Honda screen then you already have the metal brackets that will work for any aftermarket windshield.
The Honda plates will work, you only need them for the bottom holes, the upper two holes are pushing backwards not trying to rip out of the mount like the bottom.
