dduelin
Given that Honda sells approximately about twice as many Goldwings each year on the US than BMW sells in total there must be a lot of buff Honda owners.The weight difference being discussed was between the NC and the AT, not between the 6M and DCT on the AT.
No, you wouldn't notice the 23 lbs. It is just 23 lbs. So then from there, you should not notice an additional 23 lbs., because it is also just 23 lbs. Continuing the logic you can add as much weight as you want and you will never notice it. I think that may be how the 650 lb. GL1000 in 1975 became the 900 lb. GL1800 in 2016. Just be sure that you can bench press it before you buy one.
