Hmcp88
I was lubing my chain tonight when I got home from work and found something interesting. I was doing a routine once over on the bike and while checking the wheel bearings out I felt some "knocking" from the rear. I usually grab the top of the tire with one hand and the bottom of the tire with the other to see if there is any play in the bearing side to side, which can be a sign of a bad bearing. As I worked the rear wheel back and forth I heard a "knock" "knock" every time I pulled. It was ever so slight but definitely a noticeable sound. Can anyone else check theirs to see if maybe it's just a characteristic of the Cush drive or maybe I have an issue? Please and thanks to everyone in advance
