Nofear2trek
Whoosh...that is all over my head and pay grade! I'll stick with an extra universal brake switch with the spring thingy hooked to the rear brake pedal with its own switched power. I can also use it for other auxiliary brake lights to my top case and trailer later.This happens when using either of the brakes? Can be replicated by push-buttoning the brake signal without applying the brakes?
A programming particularity of the TCM that dictates that if the rider is still heavily on the throttle and the brakes are applied again and again this means lack of control?
If anything else fails, I would suggest a tiny time delay from the time the brake signal is applied to the time it is sent to the TCM just enough for the servo to release the throttle enough. Maybe 100-150ms?? Unfortunately this would mean more cutting and extra circuitry.
Ray
