at 60 and above, it's off by 1. My speedometer says 71 and the GPS says 70.
From my distance comparison, the NCX's odometer is accurate to maps. So therefore, I would say the speedo is accurate as well.
It is more likely a regulation issue than Honda's fault. Without passing all ECE regulation tests, one cannot register a vehicle in Europe any other UN/ECE norm country. The exceptions I am aware of are the SAE regulations in US and other Nafta countries and Japanese regulations.Exactly as mfb said. The odometer is accurate, but not the speedo. It looks like the speedo is off by purpose. I guess Honda doesn't want us to blame them saying "I got a 65 mph ticket but the speedo was showing 58...It's Honda fault". I had several bikes (many Honda and 3 Suzuki), they were all optimistic on the speedo speed, between 5-8 % over the real speed. My 2008 GL1800 was off 8% and so is this NC700.
So they are actually liable to supply you a vehicle that conforms to these standards (errors in this case) during the lifetime of the vehicle within the defined use limitations specified by the regulations. e.g. US and Nafta vehicles have to be certified as per SAE standards and not by UN/ECE standards.
Because GPS is proven to be accurate. Ships, planes, and nuclear missiles normally know their position within 1.5 meters. Modern units are astonishing accurate given the slow speeds bikes move at on normal roads. Older single channel multiplexing units in the days of signal dithering not so much. GPS calculates speed from distance divided by time and updates this up to several times a second. There are some errors from incorrect position but since they are so few and the unit updates so often the average speed error is in the neighborhood of .01%.
