Sub Harness
NancyG
Florida
I purchased the Honda sub harness kit 08A70-MJL-D30 for my 2022 NC750X DCT and want to install the subharness for accessories. Does anyone know where the plug is located on the bike and how is the easiest way to access it. It has a 6 pin connector.
Thanks
Thanks
Did you confirm that the accessory harness part number is appropriate for your year/model? Did your Honda harness come with instructions? If not, you should be able to download a .pdf instruction sheet. It should tell you how to remove all the necessary body panels and where the connector is.
