That's what I used, just couldn't see the scale if I was holding it in that orientation.You can use the points opposite the jaws to measure INSIDE measurements, which is their purpose.
Thanks a lot guys ! I guess they designed it so tight to prevent rocks getting in there and jamming the wheel.. I am a third owner of the bike and it came with some mods. When I ran out of chain adjustment, I found that the plates on the end of swingarms were put in wrong (concave side out). I do not understand why on earth you need to take them out for any task, so I guess I became a bit paranoid about things assembled correctly.
If the bike has a manual transmission, there is a scenario where the adjuster plates might be found installed upside down:
The owner or service shop mistakenly orders and installs a 112 link DCT final drive chain. The DCT chain is two links shorter than the manual's chain. They install the chain but can't figure out why it won't fit, then realize it would fit with the adjusters concave. Oh, they think must have first tried put it together wrong, so they leave it with the adjusters concave and they never knew they had installed the wrong chain.
If your bike is a manual, for fun, count the links in the chain. There should be 114. Even if you have 114, it could have had the wrong chain in the past and that's when the adjusters got flipped.
Is your bike a manual or a DCT? I split the difference and have a 41 sprocket on the rear but I'm thinking the next time I but a set of sprockets I would just drop all the way down to 39, I haven't heard of anyone else doing that yet so I wasn't sure if I would be spreading the gears a little too far?Awesome explanation 670, never even occurred to me.
I usually buy a 120 link chain, put it on, measure and then cut, but I never count the links after. Next time I'll just slap a 112 on it -- since I put a 39 tooth (DCT) rear sprocket on.
