It looks to me like it is from behind the bottom of the side panel just above the foot rest casting.
I second this guess as I had something like that fall loose when I had the right side panels off. It wasn't firmly attached, just a little bumper that just kind of slides into a groove molded into the panel. Thought for split second about putting a drop of glue on it so it'd stay put but didn't. Of course that means I'll probably never see it again!
I agree with that - I found the same thing underneath the bike after I had removed the lower cowl panels - it fits in a receptacle roughly halfway along the right-hand top edge of the (black) lower cowl and it spaces/buffers the panel from crankcase.
The larger "head" is a snug fit in one of the recessed bolt holes in the crankcase so it is quite easy to dislodge the rubber buffer when you remove the lower cowl panels.
