D
Deleted member 1183
A chap over on the Triumph forum is having problems also. His battery is only showing 11 volts. Perhaps the battery is problematic or has a failed cell ?
Correct. No indicator lights on dash.So in the trouble shooting section of the shop manual, what are all the potential sounding culprits to check that *don't* have a check engine light or efi flashing light code? I'm assuming this is the case, no Christmas lights are flashing on the dash, so in theory, couldn't anything directly associated with one of those be eliminated, or am I bass ackwards in my thinking?
Ack! Near a grand for everything once done? Sorry to hear fuzzy
I was thinking a pump at 400 bucks +/- wasn't too bad, but I guess with the diagnosing, labour and such, it doesn't take long to add up!
Skeptical it could be fuel filter when it comes and goes. Pressure drops to 10 psi then goes back to 60. Even when at 60 it is not steady. Also don't think fuel filter would wait until bike wars to show a problem. Yesterday rode for 40 miles before symptoms showed.
On the original problem it was 30 miles down the road after fueling for problem to show up. Similar to ride yesterday with 200 more miles on NC. Once the problem shows up it continues to get worse if I keep riding. First time was 40 miles from home. Yesterday was 25 miles from dealer. Mechanic had taken a 30 mile ride with no symptoms.
If wiring it would have to be inside the tank at the pump. Probably less likely than a bad pump.
I've looked at the manual. Hard to believe the pressure regulator or o-ring would fit the symptoms and to test would require assembly and a long test ride to verify. No ability to test the pressure regulator off the bike. Bad O-ring should be apparent to visual inspection. The symptoms do fit an electrical component that has problems when it warms up. If maintaining power to the pump then the electrical would be internal to the pump.Good for you if you can afford repairs by others and avoid needless headache (and heat stroke).
By why dealer must change whole pump assembly for ~$400 when is possible that only fuel filter assy. for $31 would be sufficient? Service manual (7-14) shows that pressure regulator is part of filter assy.
Or, maybe problem can be fixed by something so prosaic like replacing O-rings. (look in service manual - I can't insert pictures)
(I tried to insert some pictures - .jpg or .bmp but I'm getting strange message from www.nc700-forum.com:
"This is not valid image file." - on three different browsers)
The pump replacement will most definitely fix the problem and I understand not everyone has a place to work on their bike. I wonder how common pump failures are on the NC? You could ask for your old pump back if you want to check it out. Take some pictures of it and post. Im curious what the NC pump looks like.
I called dealer today to check status, Fuel pump on backorder with expected ship date of Friday, so this coming weekend is out for my trip to mountains.
