Mike Cash
I'm getting to the point where I need to change my front tire (the rear can go a bit longer) and to be perfectly frank, money (or the lack thereof) is a major concern at present.
By going with an H rated tire instead of the W rated tires that come with the bike, I can effectively cut the cost of tire replacement in half. In my case, that would be the difference between being able to change tires at all or continuing on my worn-out tires until the air is showing through.
I am looking at changing to the IRC RX-02. The same size is available in a front tire, but for the rear I would have to go with a 150/70-17 M/C 69H instead of the 160/60 that is standard. A look at the compatibility chart (PDF) indicates that while the tire is mostly suited to 250cc and 400cc bikes, there are several larger-sized bikes which accept them. The tires' load capacities are identical to the OEM tires, with only the speed rating being lower (but still way the heck faster than anything I'll ever approach). The sidewalls have a "B" rating, which I recall Beemerphile saying he always makes sure of when choosing tires, so I feel confident on at least that small bit.
Does anyone have any experience riding on H rated tires on the NC700? Is there a noticeable difference in handling or performance? Would you go with them again or were you glad to get them off the bike and back on W rated tires again? While I would dearly love to plunk down for a set of PR3s, that just ain't happening any time soon. Certainly not within the remaining life of the tires I currently have mounted. My riding is probably about 70% commuting and the rest is riding around in the mountains at stodgy old man speeds, especially through the corners. I do very little expressway riding and am seldom above 80km/h. If the handling in corners is going to turn to mush, I don't want them, but if they'll see me through for a few months and have decent handling given my riding style and usage, they would sure help me over a rough spot.
