Pabaldeagle
They are mounted with double sided tape and one hole and those little push in plastic self expanding pins. I was surprised to see they are made in Italy (not china or Japan).
so calbigbird you will be in a position to tell us whether they work. I had both sets fitted from new so I can't tell
Mike
I recently decided to purchase and install a pair of lower cowl wind deflectors. I searched Honda accessories and found that there are actually TWO Honda accessory parts labeled lower cowl deflector.
1. Honda part #08R71-MGS-A50 is the set for the DCT NC700X, they are smaller in size and require drilling a small hole in each lower cowl for mounting, and using a plastic rivet.
2. Honda part #08R71-MGS-A30 is the set for the NON-DCT NC700X, they are much larger and no drilling is required for mounting. The existing holes in the lower cowl and the holes in the deflectors align and are used for mounting. Honda includes longer screws, 2 flange collars and 2 smaller collars for mounting.
I just took a test ride with my newly installed lower wind deflectors for the Non-DCT NC and found the deflectors to provide excellent protection for feet and ankles from the cold wind. My feet stayed warm even as my legs and arms were feeling the chill. SIZE MATTERS.
I got a great deal, $68+, and would highly recommend this item.
The Non-DCT version, not so much.
You are correct. I did make a typo, it should have said the "DCT" NC700X!Thanks for the feedback on the deflectors. I bought these same ones for the SCT (single clutch transmission) from vodapas but haven't tested them yet. Looking forward to it now.
BTW, there may be a typo in your last sentence.
Is that 68 a piece or for both?
You will really appreciate the difference the lower cowl wind deflectors make in "cold" weather.
Hurry up and mount them.
I'm gonna wait a few days. Current outdoor temperature is -3*F and the driveway is packed snow.
And your point is?.....
At Procaliber they are $64.32 for the pair, but you need to spend Over $99 to get free shipping. I'm sure there are other sources.
It sort of boggles my mind that several of Honda's official accessories require some alteration of the bodywork. .....it's lazy engineering
The DCT version, not so much.
