Spaceteach
Good advice Porko,Honda uses the rubber compression nuts to hold shields etc. Not overtightening is very important. If you overtighten it it may look ok but you have probably began to pull the expanding rubber through the mount. I have put over 5000 on my large shield with no problems at all,even in cross winds of 50 mph . I have had my bike up to 90+ mph. Easy mod may do it just to have more peace of mind. Thanks for the heads up.
The compression nuts are called "Well Nuts" and over torque is really easy to do. I don't have the actual sizes of the nuts used in the NC handy, but a quick Google search for well nuts brought up several venders who listed the recommended torque. Depending on size and exactly what material is used, looks like they should not be torqued over 5 to 10 INCH pounds. It would be a good idea to ask someone who has the service manual if Honda calls out the recommended torque for these.
One other suggestion for those going with OriginalRockets stainless hardware idea is to make sure you use some type of anti-seize on the bolts. I've had stainless hardware magically weld itself together if it was repeatedly threaded and unthreaded without some type of lube or anti seize.
Bob
