been working on a new backrest/rack etc,it will come in 3 pieces and it will be easy to assemble and fit to.
its a simple method of putting one half of the rail onto the bike and the top half on , the the other half onto the top rail and swing round and fit to the bike without having to remove the hand rail altogether or seat,just remove the bolts and slide the brackets under etc.
because it is at an angle there's no need for bolts etc to keep the top half to the bottom.
once all is lined up its just a matter of tightening the bolts up.
NO CUTTING OF PLASTICS, NO REMOVAL OF HAND RAILS OR SEAT.
also it will be easier to ship with less chance of getting damage.
and quite possible at a later date supply a bigger rack to fit directly to the bottom half for those long camping weekends or vacations.
for this you wont need a back rest as all your camping gear will support your passenger.
oh and I've bought the givi brackets to so if require I can make the rack etc with mount welded to the lower half of the frame for givi frame to attached to.
GIVI 1111 KIT - Givi Top Boxes | Givi Side Cases | Givi Fitting Kits | Monokey Box | Monolock Case
