jsalemi1
It works
IT WORKS.. It is Lefty into the barrel/spacer. Also I was able to use the stem into the brake cylinder (albeit backwards). It is a bit tricky and needs careful attention not to cross thread. One must keep going in (and backing out repeatedly) as the threads feel as if they is some difference (measured in microns). The difference is so slight however it may be a result of the tooling/machining. Each time in/out you can go in further. Then back to the barrel and so forth. Eventually they are both the same size and fit snugly. I would attempt this technique with and engine.
Speaking about the right side mirror only, since I don't recall which way the left side goes: The mirror itself screws into an adapter/spacer. The mirror and it's jamb nut are left hand thread. The adapter screws into the front brake master with right hand threads. Why, I don't know.
You are just removing the whole assembly. That is right hand thread. But in the post I was answering, the question was how to separate the mirror stalk from the adapter. That thread is left hand. Go try it.
