ccrider60
I am installing an Amplink on my bike and was wondering if anyone has done so and if so where did they place it.
It's a PDM, a power distribution module. This one is about 2"x3" and 1/2" thick.What’s an amplink?
I think the fake duct (vent), and even the frunk document compartment, are gone and no longer mounting options on the ‘21On my 2015 DCT I used a Innov PowerHub (PowerHub), looks like pretty much the same thing. I put it in the space under the right upper tupperware (the fake vent). Ran the incoming power to the battery, and tapped off the left turn signal relay wires for switched power.
Thanks, I do see a location in that area, not a whole lot of choices. I think I will use some heavy duty velcro after I make a little sub base for itOn my 2015 DCT I used a Innov PowerHub (PowerHub), looks like pretty much the same thing. I put it in the space under the right upper tupperware (the fake vent). Ran the incoming power to the battery, and tapped off the left turn signal relay wires for switched power.
too bad -- that was useful space left and right.I think the fake duct (vent), and even the frunk document compartment, are gone and no longer mounting options on the ‘21
My PowerHub was placed in the same spot, but I cannot recall the relay trigger and can't find my pics.On my 2015 DCT I used a Innov PowerHub (PowerHub), looks like pretty much the same thing. I put it in the space under the right upper tupperware (the fake vent). Ran the incoming power to the battery, and tapped off the left turn signal relay wires for switched power.
I have to admit really not sure what the fake vent is; however, there does appear to be space under the center cowl on either side. Now that I have my amplink mounted to a sub base I will play around and see what works best. I'll take a couple pictures and post final results.too bad -- that was useful space left and right.
