kingjon1
I have a 2013 NC700X that has a Honda 12v power port in the frunk. While on a trip last autumn the plug went dead. I have checked the fuse and the relay and both are okay. What else could cause the loss of juice?
Frankly, the Honda 12 volt accessory outlet is kind if a joke, in my opinion. Honda chose 1 amp capacity for reasons unknown, but they do it on other motorcycle models, too, not just the NC.Why is that 1 amp fuse there? Seem the accessory harness is designed to deliver 7.5 amps in total.
Just the 7.5 in the fuse block; I have been reluctant to pull off the plastic. Thanks for the reply.When say you checked the fuse, do you mean the 1 amp fuse that may be hidden under the left side plastic bodywork, or did you check the 7.5 amp fuse in the fuseblock, or both?
