frozenpoet
Hey ocr, you coming from Texas? I'll be around jackson ms by the end of the day.
Taking a break in Clayton. Next stop Warwoman Rd and 28 to Kickstand.
I was on my way, but in Columbia, SC, my NC decided otherwise. Symptoms are: nothing in the speedo lights up, no running lights or blinkers except for good headlight. Engine will start and most of the time go into 1st gear, but won't shift higher, no horn or brake light. I disconnected/reconnected ground at the battery with negative results. Checked relays and fuses, all seem good. Ugh! Dealer in town here may be able to look at it tomorrow.
Ray
Ray
Thx...battery starts engine without problem. Nothing happens at all in the speedo when ignition switch is turned on. DCT initialized in neutral, allowing engine to start, and will go into d and back to neutral using the paddle switch. Headlight is only light working, engine stop switch functions but no horn. It's a mystery right now?Hi Ray,
I've had similar symptoms except everything was working fine, no shifting.
Check engine oil and then EOP sensors (three of them next to the clutch filter.
Maybe a bad connection? If it shifts into 1st but not 2nd, the EOP sensor on top may be culprit.
Oh another thing you can try is to disconnect headlight bulb and try.
Let me know if you need another battery, I have room to bring you one..
..something to ponder" Gearshift funtion does not work (while driving)
Only shifted into 1st gear" ref pp. 12-23 to 12-26
It happened on rough SC roads, starting from stop light in S mode, didn't shift to second, looking down everything in speedo was gone as though the ignition switch was turned off. Got off the road OK (1st gear) and towed to the dealer.
Ray
After reconnecting the battery and restarting the engine, putting the DCT back in 1st again, I would think that the codes would happen again, hmmm...Now that I am thinking again, you can not use the codes, as battery has been disconnected.
