DanWill
I re-used the OEM bolts which I believe are 5 mm. Dale can confirm that if you order his nut plates.
The oem windshield bolts are 5mm, the honda tall screen comes with 6mm bolts and nut plates. I had the tall and reused the bolts and nut plates from the tall to install the madstad. I wouldn't use a taller than oem shield without some sort of back plates, or nuts behind the mounts.
