Wildfire
- Joined
- Nov 10, 2015
- Messages
- 206
- Reaction score
- 3
- Points
- 0
- Location
- La Ronge, Saskatchewan, Canada
The chain came off the rear sprocket on my NC when slowing down for the stop-sign leaving my subdivision. There was a bit of a crunchy whir sound then the engine stopped...
I just realized I started typing a update today at work, then my job got in the way and I didn't finish.
The rear sprocket has kind of a smooshed tooth, there was cosmetic damage to the hub and adjustment nuts at the end of the swing-arm, and the chain was really jammed up behind the front sprocket. The chain is kind of gibbled now but the front sprocket, engine, and all the important bits seem to be just fine. I took things apart then back together on the side of the road and was able to ride home without incident, though it's going to remain parked there until that chain and sprocket that I ordered shows up.
The chain was adjusted two weeks prior and while I know it was on the loose side yesterday I don't believe it was loose enough to come off on its own. I am guessing a tire flicked up a piece of gravel that jammed between chain and sprocket.
Today I installed some longer bolts from the backside of the windshield nut-plate and cut down my stock screen a bit. My Madstad shield goes over the stock one like before, but now it's easily removable, and the adjustment knobs are easier to get to from the riding position. Plus it looks less like a "double windshield". Too bad I don't trust the chain enough to see if it has changed the airflow at all.
