sumo
...I dropped a 3/4" ratchet off my work bench it weighs 4 or 5 pounds and when it hit the peg on my motorcycle it didn't even slow down just snapped it right off...
LOL! Good thing it didn't land on your foot.
Rode my NCX for the first after getting home from the Hillbilly Hangout, man the roads in Kansas are straight!
There is a yellow NC 700x in an article in this month's AMA magazine. One of our inmates?
Looks good I was just looking at getting one. No problem wiring it to harness? I know the harness is supposed to be wired for one amp. Did you change the fuse they came with? Or just run it as is?Installed flasherM1 module today. Pretty extensive as far as options go. Can really tailor to your liking.
www dot 3rdbrakeflasher dot com
Installed 12V power outlet and dual usb 1A/2.1A outlet. Bought as one unit off amazon (see LBS post above for link) removed the "plate", used the marked position for OEM 12V (on backside of frunk) for the usb and eyeballed the 12V below it. Wrapped all up in elec. tape to keep it black (wired to OEM sub-harness).
Amazon.com: Auxbeam® 2Pcs 4" 18W CREE LED Work Light Bar Spot Beam 30 Degree Waterproof for Off-road Truck Car ATV SUV Jeep Boat 4WD ATV Auxiliary Driving Lamp Pickup Off-road Ford: AutomotiveI was thinking of ordering a set of these and wiring them up to the high beam. Not great with electrical, what all would I need? Any recommendations
they look like you can unscrew the lens and add some clear silicon around the edge to improve the moisture resistance. That was the only complaint I heard of. Easy fix for a great dealI just added those to my bike, I wired directly to blue wire (hot, switch to high beams) and green wire on the oem aux. wire harness. Hard to go wrong with $18 lights.
I bought the Denali light bar from twisted throttle. They are very bright. I could not imagine spending $300 for the Denali after seeing these. However, we shall see how they "endure".
