Seabee Bob
I checked the air pressure on the tires, all good! Then, I put on my padded bicycle shorts under my denim jeans and took a three hour tour.
gilligan's island intro - YouTube
Had a pair of MT60rs but on on Friday. Saturday, I picked up a roofing staple in rear of coarse. Setting at dealer waiting for a Tkc to be put on rear. A lot more sand then I remember in Az. Front Tkc on order.
... Saturday, I picked up a roofing staple in rear of coarse...
BttrThnWrk, First and foremost, replace that tire now, now, now. At one point I worked for George Edwards, the man was THE expert in all things tire. His living was as a tire expert in legal cases and if I learned anything from the man its that a minor damaged tire needs to be replaced as quickly as possible, a badly damaged tire need to be replaced now, never patched or filled with air. Believe me from your photo, that is a badly damaged tire. Even if that was what they call a plug-patch I wouldn't ride any farther than the nearest replacement. Just saying...be careful and safe.
...First any penetration through the carcass of the tire is bad because it makes a weak spot and the act of plugging it if done the way the plug manufacturers suggest (reaming the hole to clean and rough it up) actually does more damage to the penetration... Don't take chances with your life on this one, tires are cheap compared to hospital bills.
Stop-n-go FAQ said:6. Will the mushroom plugs work in steel belted radial tires?
Yes, as an emergency repair. They are not considered a permanent repair when installed in street (high speed) tires. They can be considered permanent in off-road (slow speed) tires such as golf cars, mowers, etc. F.Y.I. – How long our mushroom plugs will work in steel belted tires will depend on the proximity to the belts and the quality of installation.
7. Should I consider the use of your Patch/Plug #3002 a permanent repair in my motorcycle tire?
Safety experts all agree that a punctured and/or plugged motorcycle tire should be replaced as soon as possible. That is our opinion also.
Congratulations. You will soon be doing it without thinking about itWhat did I do to my NC? Yesterday evening, after I got home, I raised that bugger on the Center Stand, and popped it down, twice! Excited? You bet ya!! One small step for Techie...![]()
Here is some input from the people who make the Stop-n-go repair kit...
