tabrady817
ebay auction ID was: oharamanualz, it shipped from The OHaras Prime Array in La Porte IN 46350 , email
[email protected]
Actually, your review and photo are very helpful. I appreciate how honest you were about the results.I installed them [wind deflectors] both (upper and lower) yesterday. Is that worth it ? Maybe some will say yes, some will say no. As for myself, I'd say yes, just because they look cool once installed on my black NCX, but maybe that single aesthetical benifit is not worth the price tag. I will probably build DIY acrylic deflectors myself once I receive my engine guard. I'm sure I haven't helped at all in your decision !! Again, YMMV.
Dropped her for the first time. Couple of scuffs on the muffler and bent mirror. Wallet is now $59.81USD lighter after ordering a new mirror.
Ack. Sorry buddy!
As with almost all of my other bikes, I have a completely different attitude with the NCX. It's *NOT* that I don't care, or see the 700 in any way as a bike not worthy of caring about or not taking great care of, but I can enjoy riding the darned thing, spills and tumbles included, without that specter of $$$$$ hanging like a hungry vulture overhead.
I skittered around on a muddy, very poor tractioned goat trail the other day, almost binning it every couple yards or so, and was grinning like an idiot in my helmet I was having so much fun.
I’m a klutz so I was surprised I made it this long before dropping it. It was surprisingly easy to right. NOt near as hard as I remember my Hawk. Then I had to figure out how to swing my left leg over the seat since I was on the right side of the bike.
That is a reason I bought the bike. Low cost so I didn’t have to worry about every ding, dent, and drop as she is a daily rider and not a garage queen.
Installed my Calsci (sport) windshield today.
The worst bit was trying to get the front section plastic bodywork back on, broke a couple of the moulded in clips, wasn't a happy bunny!
I also have one bolt left over, not sure where that was meant to be!!
Has anyone with a Calsci had any problems with handlebar clearance? When my handlebar is in the far left position (i.e. when locking the fork), the throttle cables hit the edge of the windshield........
But on the good side, the new windshield greatly reduces wind noise on my flip-up helmet.
I also installed the CALSCI sport and have the exact same clearance issue on the right side only. Rotating my RH throttle/brake assembly upward, will only increase the interference. I noticed that my upper cable "90 degree tube" assembly was not bent to the full 90 degree angle, similar to the lower one- so it sticks out further. Also, the CAL SCI edges at that inset portion of the screen were extremely rough (not sanded and smoothed like the upper portion) so, whenever my bar was turned to the left the windscreen started to dig into and rip the throttle cable sheath adjacent to the adjustment assy. I expect some-day to remove all cowlings and remove the upper tube from the throttle mount so it can be properly bent to the full 90 degree angle. In the interim, I have installed a short section of vacuum tubing over the brake cable to protect it (ID to match the OD of the brake cable sheath). I have also removed my screen at least once to spend an hour sanding and slightly rounding those crudely unfinished edges of the CAL SCI screen. During some snowy/icy day I might remove it again, to finish it a bit more and possibly flame polish the edges.
One thing (among others) that I do not like about the CALSCI screen is: 1- at night, the headlight beam is picked up through the lower edge of the plexiglass windscreen and it glares up through the entire windscreen. In a way, it looks "cool" but when driving home every night at 2AM in the dark, the only returned glare I want to see, are reflections from objects ahead of me on the road. I don't need a map reading light while driving my bike in the dark. 2- Especially annoying is the reflection of the entire guage assembly bouncing off the interior of the windscreen when it is pitch dark at night. I also don't need an upside down mirror image of my dashboard flashing back at me when riding in the dark. A hood, extending a couple inches over the top of the guage assembly will eliminate the reflection however, that is a task being reserved until after I resolve my rediculous engine vibration, when under load.
My biggest pet peeve with this screen is with the mounting of the windscreen and the excessive amount of pressure required to hold it , once bolted. If you haven't noticed, the windscreen is held in place on the two canti-levered bars, by using a compression grommit. Unlike the factory windscreen which is curved perfectly to match the arc of the mounts (also the windscreen holes fit perfectly in front of the bolt holes of the rubber holding devices), the CAL SCI screen must be "pulled" around into the desired arc by 2 1/2" in order to get it to come close to the final mounting point. This screen is very thick and it takes quite some pressure to hold it in place. This holding tension places an undue pressure on the rubber mounts, thus pulling on the grommits (from behind), at an angle that is not perpendicular to the mounting holes. All 4 of my rubber mounts have been completely distorted from this. I contacted Mark regarding the need to have the windscreen pre-curved the extra 2 1/2 inches, but apparently that is not on his priority list, nor is the edge rough finish on 50 perecent of the windscreen. I guess we would have to pay $300 to get a truely finished product.
So why did I keep this screen you ask, after providing feedback to Mark (who advised me to return it)? It does work extremely well!!! At the time I purchased it, no other aftermarket screen that I researched, had the height or width I desired and, when I tested it on my bike, it performed very well. It appeared a bit large initially, but at 5'6" my visibility over the "sport" screen allowed me to see the road ahead, at about 15 or 18 feet. Once I decided to keep it (and after discussion with Mark at CALSCI), I had to ream out the bolt holes over 1/8" (wider) to improve the bolt position and help allevaite some of the angular pressure on the rubber mounting compression fittings. The bolts are not going to come out perpendicular to the mount without having the screen formed to fit the required arc. So, at some point while driving down the interstate at 70 MPH with a 40 mile headwind, and it rips loose, I know that I can contact CALSCI to resolve my situation (whatever it may be), because I offically informed him of this problem.
Ed
