Adjustable lowering links. How long do I want them for 1" lower?
booblinker
RICHMOND TWP, MI
Does making them longer than stock or shorter than stock lower the bike? Is there a ratio? like .5" longer = 1" lowered, or raised. etc etc.
1wiseguy2
Rockford, Illinois
I believe that longer is lower. I will go look tomorrow as I have two lowered to different heights in the garage.
mtiberio
virginia
This winter I plan to remove my adjustable lowering links. I'll make some measurement and comparisons then and report. I do remember I lowered it as far as it would go before the tire hit the inner fender. The reason I want to pull them is, they are cheap chinese, and after 2 salty winters, I worry about the heim joints snapping. I plan to replace the heim joints with some nice stainless ones, and put the links back in service with a little less lowering.
1wiseguy2
Rockford, Illinois
Do you guys use centerstands?
Yes, one bike has normal center stand. Hard to pivot up for my daughter bit with practice she can now do it. The DCT my other daughter has has a NC700S center stand and it is perfect for a lowered bike. Very easy to put up.
1wiseguy2
Rockford, Illinois
I believe longer is lower.
Soupys Performance || Motorcycle Adjustable Kickstands, Motorcycle Lowering Links
I have two bikes using these. Very good quality. You can make the slightest adjustment and not have to remove the link. Took me 25 minutes to install. Have someone pivot the bike up onto the kickstand and front tire. This unloads the rear suspension. With bolts already loosened you slide them out and replace the dog bones and then reinstall the bolts. Lower bike and tighten back up. Lower as necessary while person is on the bike.
drdubb
Raleigh, NC
When was the NC700S imported. I don't see the parts did he at my normal source.
The NC700S has never been sold in the United States.
You can purchase the NC700S main stand from the Japanese source Web!ke.com
1wiseguy2
Rockford, Illinois
WeBike also has a center stand stopper for around $35 if you have an after market exhaust.
drdubb
Raleigh, NC
I saw that at Weblike, but it indicated fitment for all of the 700's, so I thought it was the same length as the X.
1wiseguy2
Rockford, Illinois
I believe that the 700S stand has a bit narrower stance if that matters to you. I can measure the difference if you would like me to?
WPZ
Chicagoland, Illinois, USA
In fact, we just ordered the S centerstand from Web!ke and the stopper, too- her NC has a Two Brothers noisemaker.
The OEM centerstand wasn't easy before the lowering, and it's murder now.
The S stand is allegedly due in four more days. Must be a pretty fast boat.
We salute 670cc for the pointer.
Michael Moore
In the fog of San Francisco
Besides checking for tire/fender clearance don't forget that lowering the bike will also reduce vertical and leaned-over ground clearance.
CTX owners have reported some issues with the available center stand stops that bolt to the pivot bracket on the frame, mostly it sounds like the bolt in the stop or the bolt holding the stop to the frame is a bit small or soft.
https://www.eurospares.com/graphics/FF/Honda CTX700/NCcenterstandstopperOverRacing.jpg
I made my own and bolted it to the upper frame plate rather than using the bolt that retains the center stand pivot spindle. This way all the retaining bolt does is keep the stop from falling off when the stand is down, the flat plate on the frame is what takes the thrust when the stand is up. It may be overkill, but it gives me peace of mind.
https://www.eurospares.com/graphics/FF/Honda CTX700/centerstandstopper_0991.jpg
https://www.eurospares.com/graphics/FF/Honda CTX700/centerstandstopper_0994.jpg
https://www.eurospares.com/graphics/FF/Honda CTX700/centerstandstopper_0996.jpg
https://www.eurospares.com/graphics/FF/Honda CTX700/centerstandstopper_0998.jpg
https://www.eurospares.com/graphics/FF/Honda CTX700/centerstandstopper_1002.jpg
cheers,
Michael
